Couple of things regarding to Grid settings. Based on b307
- The width of the Width & Height fields in Preferences are really wide, which results in the Height being hidden or needs horizontal scrolling to show, when the pane is in default(?) width. Make them less wide?
- "Grid W/H" could be named "Grid area W/H"? Grid W/H at least to me sounds like the distance between the grid lines, but that is what Snap Distance modifies currently.
- Maybe add "Grid major line distance" and "Grid minor line distance "settings. In metric those could default to 1m and 0,25m.
- Would be nice if there was a visual difference between the grid major and minor lines. Major lines a little thicker than minor lines, with coloring options for both.
- If the above make sense, then add an option to show/hide Snap distance and also to color the snap distance lines separately.
