There may be good reasons to not do this that I'm not thinking of but...
If you're in Control mode and if you've got a moving light on and you're showing focus handles, right now you have to select the light on the command line first, and then grab the focus handle to start moving it. That feels like an extra step. I want to just be able to grab the focus handle and start dragging. If I cick on a light fixture symbol, it posts it to the command line. If I click on a channel magic sheet object, it posts it to the command line. Clicking the red dot should immediately post as well and let you begin your drag command. Also a bonus in that you don't need to figure out "what that channel is" first. If you see a light pointing DL and you want it pointing it center, it would just be quicker to click and drag right out of the gate as opposed to having to confirm which light that actually is first before you can drag.
Just my two cents
thanks
Cory
