Handling 16bit sACN input in ShowControl as 16bit values when routed to a 16bit channel
Dear ETC-People,
I like the possibility to have an incoming universe routed to another one using the options I have in the ShowControl Tab.
I also like the idea that I could actually capture incoming data on EOS. I could even grab data to create cues or presets from that including MovingLight Data that way if the patch of the console sending to EOS and the patch in EOS match.
The only bad thing is that 16bit values are not being handled correctly. It seems that only the LSB values are routed to my patched fixture in EOS but the value of the MSB is set to 0 even if the incoming data is saying something else.
It would be really great if that MSB value wouldn't be lost in translation.
Cheers Paul.e
