Idea:Add a small label for last palette used to table and magic sheets.
Current issue: When using palettes any adjustment turns references to a + or their actual data from reference labels.
Current scenario: Fos/4 x8 in direct mode, adjust light to 3200K, record palette. Adjust the yellow value down two points. There's now no data on where you started except by memory. If there are many adjustments or it is looked back on a few days later then this info is lost.
Solution: Have the ability to add a last used reference label. A small label above current adjustments or replacing the + sign that appears when adjustments are made with the paletteName+.
