Hi! I would love to be able to use the learn button to record follow times into cues. Example: [Learn] [Cue] [Follow/Hang] and then it counts the duration between presses of the Go button and applies that duration as the cue’s follow time. A similar feature is available for time code events, using the Learn button to determine the time that a cue should be fired
