[Load] + [Go]/[Back] to load pending cues
This would essentially be a Go/Back-Shortcut for the pending cue. Allowing us to quickly skip to a cue without having to type it in first.
Sometimes you have to skip one or more cues quickly, but you still want the marks to happen for example.
  • I would think of [Load] + [Go]/[Back] working for the pending cue in the same way that [Go]/[Back] does for the active cue.
    [Load] [Go] [Go] [Go] would therefore also be possible. In my mind this would respect mark-times but could also have it's own time-override in settings.
    I think syntax-wise you would be right about it Load/Next, but I think Load/Go is more practical when it comes to the location of the buttons. Just seems more intuitive, especially for something that might has to be done quickly in the heat of the moment.
  • So, are you thinking this would be a shortcut for [cue] [next] [load]?  I would suggest that [load ] + [next] might be more syntactically / grammatically correct. This would also possibly open up [load] + [last] + [last] + [last].
