'Locking' encoder pages to stop encoders moving around [Apex]
Hi all,
I'm running into an issue caused by the Apex encoders display being 3 pages in one. I know already a current feature request about unifying the pages (https://community.etcconnect.com/control_consoles/eos-family-consoles/i/feature-requests/apex-in-extended-mode-main-encoders-mini-encoders-should-be-1-page-instead-of-3) but this may be another way of approaching it. Please could I be able to 'lock' each set of 3 fader pages into a position on the encoders so that they don't shift about while moving through encoder pages? In effect this would mean disabling paging inside parameter categories when there are 3 or less pages, or jumping pages by multiples of three when stepping through when there are 4 or more.
I really like using the bottom right mini encoder to page and sometimes press an encoder category when I'm already in it, and would like both of these actions to always end up with my encoders where I expect.
Best,
Toby
  • In this situation I'm already using custom and have filtered out the parameters I don't want down to just 1 apex 'page' which is actually 3 encoder pages. I'm trying to stop the parameters rotating between the three different pages that are all on display at the same time.
  • This sounds like something using custom encoder layouts would natively solve, and then when you need to get access to the full set of parameters you drop out of custom.
