Magic Sheet Defaults: A settings menu that provides the ability to set the default or modify characteristics for Magic Sheet Objects on an individual magic sheet level as well as a show file level
Primary (Assuming it would be within CIA setup): Set default MS background color. Set default font, font size, font color, color characteristics and target layouts for each type of MS object references at insertion.
Secondary (Assuming it would be within MS Editor Settings): Set font, font size, font color, color characteristics, and target layouts for each MS object type. This would set the default for new items inserted on the specific MS and modify current items on the sheet. This area would also give a home for the “change type” function to change every object of one type to another. An option would need to exist to choose whether or not to use primary or secondary settings.
