Magic sheet max screen usage
When selecting a magic sheet the zoom to all function always leaves quite a large unused area around the outside. At this stage only way around this is to use snapshots after zooming to the desired size. A sizable frame indicating the edge of the screen editing mode would be good. This way the user can determine the size and amount of objects fitting on the screen and the frame will always snap to the edge of the physical screen in live mode. This way the user can always utilise the maximum screen realestate.
Thank you
