Marktime table
I would like to set individual mark times for my cues. For now i only know that general setting in setup. I am not sure if others would like that feature as well, but in theaters that very feature would definitly benefit our handling with some complex situations. Would that be possible?
Best regards,
Oli
  • I'm guessing this is with automark enabled?
    I don't know if the behavior persists with automark, but when marking manually, adding discrete times to non intensity parameters in the cue that they come up will cause those parameters to mark in that time.  I do this frequently when I know just one or two lights need to mark quickly and I don't want to set the mark part to a fast time that would cause the entire rig to swing around violently.
