Offset - Order by Delay / Order By Time
I've asked for this before, but I'm going to ask again....
Please please please please please please please please can we have a way of selecting channels in an order based on any existing per-parameter delays or times. I'd imagine this could be hidden away under OFFSET.
So sitting in a cue where chan 1 del 1, chan 2 del 3, chen 3 del 2, chan 4 del 5, chan 5 del 4
Going 1 THRU 5 OFFSET {order by delay} would select them in order ch 1, 3, 2, 5, 4.
{order by time} would order based on time.
{order by duration} would order based on time+delay.
{reverse} and the other offset options could be appended.
Yes it is nteresting to consider what should happen with channels in a range that don't have specific times/delays set. and perhaps there should be an option to filter/ignore those.
Yes, it is interesting to consider what should happen to channels with different times/delays on different parameters, but I'd presume that the usual filtering using parameter filters would work here to help make decisions about this.
This would be so, so useful.
Thanks!
Rob.
