OSC "Connections"
I would love to see the ability to separate OSC and Strings settings into “connections” that can be turned on/off individually as well as globally. Currently, enabling/disabling OSC and Strings is an all-or-nothing toggle. There are many times where I want to only disconnect from one target device but not another.
For example: if I am triggering audio and video using OSC as well as using a custom OSC widget to feed additional data into Vor, I want to be able to turn off the send to just audio while I work out some kind of sequence that has sound sound effects without losing video and/or the Vor data. The current workflow is either to radio back to sound to ask them to disable OSC, or to turn off OSC on our end which then means we’re not triggering video anymore.
Ideally each connection would be as simple as name, destination IP, and port.
