Pan/Tilt Inverts Should Be Enable/Disable-able in Macros
You can indeed toggle Pan/Tilt inverts in Macros currently, but you currently cannot do this predictably! I.E. in the macro editor you cannot Type:
[Invert_Tilt] [Enable] [Enter] and it only Enable, if this is performed on a fixture that already has Invert Tilt Enabled, it will Disable it and still only acts as a toggle.
