Per Direct Select Double Click
Instead of Direct Select Double Click being a device option having it as a per direct select option would make it a lot easier to start bringing it into workflow.
Unfortunately, right now it's a very dangerous option to have enabled (One fat finger press away from throwing strobe onto every unit in the rig!)
However, if I can just enable it on specific direct selects I can see it being a lot more useful, say on presets, or show intensity pallets.
  • I think I understand that you want to require some DS to be double-click so that you can avoid accidentally triggering something unexpected.
    I would suggest that you might want to use logical/physical partitioning to avoid these sorts of problems, and/or making things two clicks away. For example I have a timecode disable button, that really just loads a second screen for a confirmation.
