That's what it is. If you're running an Intensity Effect over the fixtures that should be recorded into the Intensity Palette. I want all the data that's contributing to this live look when I record the Palette.
This would make it easier to busk since you could quickly combine effects from different parameters without needing to use presets when your Effect is only a single type.
