Hey guys,
I like using the ESD for editing effects in live, but if I have several effects running at once and I type [effect] on the command line there’s no easy was to select all live effects at once. Instead I have to type in the number of every single effect I want to edit. Could you please add an (all) softkey that appears after [edit] is pressed in live?
Obviously I could make a global effects master to control them all that way, but I prefer the ESD method because it doesn’t change the speed of all effects throughout the show (only on a cue by cue basis).
Thanks
Greg
