It would be helpful if after checking address, you can use select last to reselect the last adress
As a workaround, you can use [Shift]+[Enter]That will bring the last 5 terminated Commands back to your Comanndline, unterminated.
I'd like this as a feature, but still keep the regular select last behaviour. Maybe a shift + select last action. (though I believe that combo already does something)
