I can select magic sheet channel objects one at a time and Eos will automatically insert a plus between them. If I select a magic sheet channel object and then type a channel, it gives the error message "Error: Channel list is empty". I can't tell you how many times this has happened to me.
I would like to see typing a number after selecting a MS object terminate the command line before posting the new channel number. This would be good if you forget you have a MS object selected and want to select a new channel.
