While 3.2 added a new search tool such as search by channel or cue label, this actually also works with Macro -- but for that to work you need Macro on the command line. There is no true way to get macro on the command line without a work around such as
- Be on the macros tab (macro-macro)
- Then by typing [Next] [Shift]+[Enter] [Clear]
At this point you now have Macro on the command line and [Shift][About] will properly search the macro by label. It would be great if you could get macro on the command line from LIVE or anywhere else by just pressing [Shift]+[Macro] or some other non-hackish way to access it
For reference, see: RE: Feature Request - Shift + About for Macros
