Subs on Direct Selects
Hi there,
It would be nice to have the subs on direct selects and tapping the tile would be like a direct action or like you pressed the bump button. This would be a more flexible alternative to having the fader module open with the fader suppressed. A quick way to have lots of interaction on a touchscreen. I know the same could be done on a magic sheet, but I really like the workflow of the custom DS system way better than making a magic sheet.
Thanks,
Tyler
  • perhaps if possible have direct selects have a function on press or double tap menu. So I can choose the action of making the day selection.
  • I think this would be a great feature. Maybe adding a double tap on the direct select would take you to BLIND>SUB#. So it was easy for editing. Or a single press selects the full fixture that is stored in the sub not only the assigned sub parameter in the live table. Then if are using the sub for intensity only you can still have a group sub selection that includes all of the fixtures  parameter in live with out having to use an additional group selection that could easily get out of sync with your sub.
