Planned for Future
Tap tempo on a bump button
Hi,
Can you please make it possible to assign a bump button to control the tempo of an effect using tap tempo?
Thanks
  • A work around for this is 2 x macros that can be assigned to bumps in fader config.
    One to do Learn Time, the other just as an Enter button.
  • New year, new luck... Any news on this topic?
  • As said above, this probably won't be intergrated into v3.0...
  • Any update on the tap-button?
    I've set up a work-around using Luminosus, OSC and a Midi Controller, that does basically exactly what  described.
    A native solution would still be appreciated though. Especially since Luminosus is no longer being worked on.
  • To expand on this, would it be possible for:
    Effect time to be assigned to a Global FX master (currently you can limit the control of a GFXM to a selection of effects in the menu of the GFXM, but it would be nice to assign the Speed of the effect to a GFXM in the effects menu)
    Cue time/cue list time to be assigned to a Global FX Master
    Making it possible to sync multiple cue lists and effects at the same rate.
    --- Could we also have modifiers to clue lists/effects assigned to a Global FX Master that would allow for further adjustments of rate, such as speeding up or slowing down by a factor of 2, 4, 8, 16, or 32
    The BPM/tempo master would then link to, or a user selection, of Global FX Masters. The BPM/tempo master should be able to be mapped to a fade or function independently as a single tap button. The BPM master should be able to be set by a macro; so that a user could set the BPM masters BPM by a cue’s execute command.
    Thank you!
