The position materials in the effect can be recorded into the focus template.效果里的位置素材可以被记录到焦点样板中。
我们可以一些对称的焦点效果获得不错的造型,我需要把这些造型记录在我的焦点样板中进行使用。
Edit by eos.moderator after a conversation with OP:
The OP's request is that parameter values generated by effects are recordable while the effect is still applied to the parameters.
His workflow is using an Effect Sub to run an effect and pause the effect by pulling down the fader. The resulting look (parameter values, but not the fact that an effect is present) should be recordable to cues, presets and palettes, without having to stop the effect (using Stop&Hold exit behavior).
