User Setting - Disable SC Learn by Default
Probably for User Settings, but possible for System Settings:
The ability to set the default behavior for Macro SC Learn to be either disabled or enabled by default. Unless I'm overlooking something, it always default to SC Learn Enabled. And while I understand in some environments and workflows this is desirable, in other situations, such as ours, we only ever want to learn cues -- unless we very explicitly want a macro to be learned (mostly RTC events).
  • I was just helping someone who accidentally learned a macro into show control, so I came back to make sure this request was out there.
    Just to add some clarification to this request -- my proposal is that this setting would only impact macros at time of creation -- e.g. when you create a new macro, the default state of learn SC is based on this setting -- of course, thereafter the parameter can be changed in the macro tab after the fact.
