EOS Fixture Editor??
Ok, I'm probably having a blonde moment but I can't find this thing. It's not in the Eos manuals and I don't see it anywhere in the EOS downloads section. I want to create an entry for some old HES powerscans.
  • You will want to go into Patch--
        Once in Patch you need to specify a channel for the location of the devices.
        Press/Click the Type button in the CIA display.
        You should get softkeys in the bottom of the CIA that read Show, Manuf and User. You want to press/click User. The softkeys will repopulate and one will display for Edit. Press Edit and it will take you into the Fixture Editor for Eos/Ion. If you have any questions about the editor feel free to call Technical Support at 800.688.4116 and ask for Technical Support.
    Josh Selander
    Field Service Engineer
    ETC Las Vegas
  • And for more information... It's in the Eos v1.2 manual and later in the Patch chapter in a section called Fixture Creator (p78 in v1.3 manual). And don't forget, all of our manuals are available as a free download from the ETC website.
    Here's a direct link to the manual I'm referring to:
    http://www.etcconnect.com/docs/docs_downloads/manuals/Eos_v1.3_Operations_Manual_RevA.pdf
    I hope this helps.
    -Steve Traut
    ETC Technical Communications Supervisor
