I am beta testing Nomad 2.4 (currently on build 142) using one of the Eos programming wings. I noticed that there was a new firmware update for the Eos Playback Master came with the software, version 1.0.1.9.0.6. Upon upgrading said firmware, the master playback and it's controls no longer respond (and all of the playback modifier keys are lit up, top four are green, rest are red). The shell reported that the upgrade was successful and the logs confirm that the firmware was successful. However, it appears that Nomad no longer detects the playback section of the programming wing, as the Playback tab no longer appears in the Peripheral Test application. My computer also shows a new drive named BOOTLOADER with a single file, a blank text document named READY.
I guess my question is this: is there a way to rollback the firmware on the playback wing independent of the Nomad software?
I am currently running the Nomad software on a PC running on Windows 10.
Thank you.
