Bug: 2.5.0: Mouse wheel doesn't work properly
The mouse wheel doesn't work to scroll a channel, patch, or record target table display or zoom it when the mouse pointer is on or next to any channel.
The same behavior is true for the PSD.
The scroll wheel works fine to scroll a direct selects display or tombstone view.
I'm downgrading to 2.4.1 until this gets fixed. I use the wheel all the time.
  • I think it's a consequence of in-cell editing. The mouse events aren't always getting to the window that needs to receive them.
    Position the mouse inside the tab but not directly over the scrolling area. I've gotten in the habit of hovering over the tab label for most consistent results.
  • RND 0039864: Mouse wheel only scrolls grids when you are not hovering over the grid
    That's a defect. Thanks. For now, hovering over the tab label and moving the mouse wheel works.
  • Dan, I would expect that scroll wheeling on the tab label of a magic sheet tab would zoom in and out (like scroll wheeling in the tab itself does). Right now, scrolling over a tab label of a magic sheet moves the contents up and down.
  • Hold down the left mouse button while scrolling to zoom. I'm pretty sure it's always been this way.
  • I disagree. In a MS tab (and only there) the mouse wheel zooms (at least used to). Click and wheel is for the other tabs
  • Ueli is correct. Left click and scroll is not required for magic sheets. My only comment is that it's weird that scroll wheeling in the MS tab content zooms, while scroll wheeling over the MS tab label moves the content up and down. I think they both should zoom.
  • I have 2 computers in front of me right now, and I ran a test on MS behavior on 2.4.1 and 2.5.0
    The results were the same for both software versions.
    While not editing the MS:
    In MS contents: the wheel zooms and the pointer location is the center of the zoom. Left-click doesn't modify the behavior.
    In MS tab label: the wheel scrolls the content up and down. Left-click makes the content zoom where the center of the frame is the center of the zoom. (Vindication for sk8ers_dad)
    While editing the MS:
    In MS tab label: sometimes the wheel zooms and the center of the screen is the center of the zoom, sometimes it moves the content up and down, and sometimes it moves a selected object up and down. I don't know what causes it to do this.
    Left-click and wheel zooms and the center of the screen is the center of the zoom.
    Paul: I would guess that there may be people who don't fit all their MS objects into one frame at the same time and use the wheel while hovering over the tab label to scroll the MS up and down. I'm not one of those people but from that standpoint it makes sense to keep it the way it is.
    I really like the behavior of zooming based on where the mouse pointer is.
    I don't care what hovering over the tab label does in a MS because it's so intuitive and easy to hover the mouse over where I want the center of the zoom to be and then zoom with the scroll wheel. When I need to move the MS content, I right-click and drag. When I need to move a MS object, I left-click and drag.
    However, I am curious to learn about why left-click and wheel behaves the way it does in MS editing. It seems buggy to me.
