Simple House Lights Control
Here at Le Petit Theatre in New Orleans, we run our lights with an Ion. It's a great fit for our space, and gives us all the flexibility we need. The only issue we're running into is that the house lights are also controlled by the Ion. During shows and work calls this isn't a problem, because we have enough people on staff who know how to use the board. The problem comes between events when cleaning staff needs to get in and have light to work by, or someone needs to give a tour of the space on a day when no one is working. Obviously we're not leaving the theatre completely dark, but sometimes they need more light. What I'm looking for is a good way to make a "light switch" I can put near the theatre door that will turn just the house lights on. I have not yet found a ready made solution for this, without buying a whole Unison system, which is a bit much for one circuit. If there is pre-made simple solution, please let me know. Some ideas I had: - Buy a small 4 button wall-mounted DMX controller and put it inline before the dimmers (~$600) - Mount an iPod touch with the iRFR installed (not user friendly for novices) - Buy a home light switch, and use a Rasberry Pi (or Arduino) to make the switch send MIDI messages to active a Macro in the Ion to control house lights. I'd either run a long midi cable, or use midi over Ethernet. - Buy a ETC Unison Heritage wall panel, and figure out away to make EchoConnect talk to the Ion? It seems like this should exist, but I haven't found it. Or some combination of the above. I'm curious if anyone else has come across a similar problem and what solutions you've found that work well. Thanks!
