Hi
I have a current set up incoporating the following:
a) Win 8 laptop c/w 2nd screen
b) Gadget two
c) lxkeys console.
I have a mixture of intelligent fixtures coupled with 100 ways of dimming. I split the rig into a) all generics on U1 and the fixtures on U2.
I had intended to use the gadget two set as U1 & U2. Regarding the address count on my nomad dongle, I was well within the 512.
I could not for the life of me get the second port to output on to U2. When I re addressed a fixture to be in U1 and set the second port to be U1, I had control etc.
I tried various combinations to get U2 to work. I gave up after 2 wasted hours. To confirm, the issue was not cable or fixture related. The issue was that the Nomad would not output anything into U2.
I repatched the rig into U1 and all works.
I am wondering is there an issue with accessing U2 via a gadget two? I looked for firmware updates to no avail. The 2nd gadget port works when set to U1. I expected to be able to access the U2.... as long as the address count was sufficient.
I am running 2.7.2 build 17.
Is there an issue, limitation or just me?
Cheers in advance.
Eamon
