Hi All,
So, I should probably know how to do this... but my brain is a little fried at the moment. So any help would be greatly appreciated.
I have a show file from Venue A. They used the fixtures that they have in house. I am now transferring the show to a new venue where all the fixtures are different. I can change the fixture types in Patch - that much is not a problem - but here is where it is getting tricky.
The new venue (Venue B) refuses to change the soft patch of their units to match our channel numbers (a rep house) so not only do I need to swap fixture types, I also now need to swap channel numbers about - how do I make all of these changes and still keep all the channel data for the fixtures?
Is there an easy (easier?) way to do this?
Thank you
D
