Pixel Mapping LED Tape
Hi There,
I am working on a pixel map setup with LED Tape and have successfully patched and set up the layout. I am mostly using it to make gradients using the effect layers with a movement of 0. I then record each gradient to a cue in order to fade smoothly between them - and that is where my problem starts. The lights seem very choppy when fading between the different gradients I have recorded. It’s almost like the content is grainy or something. My pixel map is a large L shape - a single line of 200 pixels x 50 pixels, and I up the content to almost 400 pixels wide to be able to move it across my pixel map with pan/tilt.
- I’m thinking I may have made the content too large and it can’t be this many pixels, but it doesn’t seem very grainy on the preview, so I’m not sure.
