Eos Programming Wing
Hi Everyone,
I am doing some research about possible new lighting consoles and I came across the Eos programming wing and I'm confused about if you have to have a gadget or a puck alongside it to output dmx or if you can just do that with a nomad key and a computer and the programming wing? Also if that is true, through that setup would you also be able to run hog 4 like you would be able to do with a gadget or puck? If so, would the programming keypad on the wing work on hog 4?
Campbell
