Anybody an idea about how to set and change the playback rate for cues over OSC?
Thankls
Peter
Thankls
Peter
But my last hope: Is there a way to set the rate for the running cue? Or do you need to get the cue number for that and use that in your command?
You could try leaving the cue number blank, it will default to the cue number on the command line (typically, but not always the currently running cue).
I don't know what a "Max messagebox" is, so I can't help you there.
