Flash button issue - Hog 4 show on Hog 3
Not sure if this should be here or in the Hog 3 forum...
Show initially programmed on Hog 4 PC v1.1.3
Then moved onto Hog 4 console running v1.2.0 and more programming done.
Today I loaded it onto a Hog 3 v3.2.6 and the flash buttons don't work.
Open the list options, and "none" is selected for the button. Changed to "flash", and now +go and +release work ok, but the intensity level remains at zero.
I tried reprogramming the lists on the Hog 3 but the same thing happened, including "none" being selected.
Luckily everything I need a flash button on are lists with a single cue, so I reprogrammed them as scenes and all is good.
Leggy.
