I was in the spreadsheet view and saw a column for Direct. Can that make the pallete a direct selection with the fixtures recorded inside it? Or what does it do? It defaults to No, but what changes when its set to Yes?
"Note that converting a palette to a direct palette will not alter any programming done previously using the palette; cues and scenes already recorded will still contain references to the palette. Only subsequent programming will be effected."
