issues building custom bulb ordered multi intensity and 16bit rgb
Trying build a custom bulb ordered i87 where the sub intensities are 4,5,3,6,2,8,1,8 and also trying to build a 16 bit rgb, rgb cool white and rgb warm white. All 16 bit. When I build these types I loose the master intensity. Help. I build, creating, add, then patch, and I see the sub intensities, and colour intensities but there is no master intensity control either in the programmer or the modifier. Discuss!!!!
I'm not 100% but I believe if the fixture doesn't have an actual intensity parameter, then the virtual intensity parameter that the Hog attaches to the personality is something that can only be achieved by an HES-written personality - it's something that the fixture builder cannot produce. If your fixture does have the intensity on its DMX chart, then no idea, sorry!
Thanks for the response! Cheers. An ability to custom arrange sub intensities would be a cool thing for future revision. In the meantime I can fix with my intensity pallets cheers.
