I'm running into an issue with time only palettes that wasn't there before. I'll try to explain.
In my busking show file I make use of time only palettes so I'm able to change timing in several cue's and scenes at once for all different paramaters.
For example:
- Colour Palette 5 is time only 0 seconds;
- Colour Palette 5 is time only 2 seconds;
- Colour Palette 10 is the palette I use to program cue's and scenes;
- If I like to make all my colour bumb-lists to have a time of 0s, I will copy/replace Col Palette 5 to Col Palette 10.
- If I like to make all my colour bumb-lists to have a time of 2s, I will copy/replace Col Palette 6 to Col Palette 10.
This was working fine before the pandemic, not sure what version of Hog 4 OS I was using back then. Now I'm updating my show file in Hog OS v3.17.0 and I'm running into a problem.
There is a problem with the timing executed in a cue and the timing showed in the cue/palette itself. So there is a difference how HOG 4 OS is executing the fade time of a cue and the fade time showed in the cue-editor.
When I replace the palette used in the cue (Col Pal 10), the fade-IN time is changed correctly when replacing the palette used in the cue, but the fade-OUT time is NOT changed at all. Which is weird because in the time only palette the fade-in and fade-out time is the same (e.g. both 0 seconds or both 2 seconds in the example).
The fade-out actual used to go from cue to cue is the time that was in color Palette 10 when recording the original cue.
