Is it possible to resurrect the "Burn CD" functionality from the Hog 3? We do corporate shows, and when its time to upgrade software I like to archive all the old shows before upgrading. The hog 3 burn cd function let you make backups of all shows on the console from the show browser window, without having to log into each show, backup, log out, then copy all of them to a thumb drive. I would like to be able to choose which ones to archive, I don't need a backup of my bench test file, or 15 'new show_#' files.
If you're one a Roadhog or other console without a mouse handy, you can use [PIG] to select multiple items. and you can also use [PIG][SET] which is the same as right-clicking. It might be easier to select them this way and [PIG][SET] (Copy) > (PASTE)
