My roadhog 4 won't update. It has a an error during install (full console)
Error states: Failed install hog4 or something.
Updating from 3.15.1 tot 3.16
Any ideas? Thanks
Any ideas? Thanks
Some things to check:
If these don't work, please send a photo of the exact error that pops up when the full installation fails.
Thanks for your reply. I tried three different USB ports with The Red console restore USB stick that came with the console. In my control panel it sets the hognet adapter is set to the internal look back adapter. No other Network interface is able to Select. The fixturenet output is set to a Network interface card.
How can I check if My Network interface has a Mac address?
Right under the Network Adapter is text that says MAC and it usually is full of letters and numbers like 00:90:a1:0a:be:a4. It's right above Link State
Found no MAC-addres. Only found the following:
Seems like the Hognet adapter is broken or something.
Any suggestions for repair?
Your MAC address is under the Hognet Tab, I have highlighted mine
It appears your console has lost its MAC address, and the console will need to be sent into HES for repair. Without a MAC address on the HogNet port, the console cannot be updated, and the HogNet port will not properly function.
Please contact me at kyle.kurtich@highend.com with the console's serial number and I can start the repair paperwork.
