Hello all,
We are running Obs II 4600 5.1.1
Rosco I-Cue mirror fixtures are displaying move/stop, move/stop, move/stop, etc behavior during a live move, 10 sec fade time. Cycling about 2 stops/sec.
The fixtures are set to 16-bit operation. ML personality is set for 16 bit (Pan, Pan Fine, Tilt, Tilt fine)
Operation is smooth using encoders, and choppy only during cue playback.
Behavior is the same in both DMX & eDMX environments.
DMX transmission speed is set to MAX.
S4 Revolutions and VL 1000s in the same show do not exhibit the same problem.
Has anyone had a similar experience and hopefully a workaround?
Cheers,
Tom
