Expression Boot ROM
My Expression 3 is occasionally giving me this information on powerup:
Expression 3 / 400 Boot ROM ver.3.0
DRVSPACE
                  select a program to run using + or -
No Help Available
Soft Keys are as follows
S1 RUN PROGRAM
S2 through S6 Empty
S7 RECORD TO FLASH
S8 RUN FROM FLASH
Why does this happen?  After several reboot attempts, the console would power normally.  Now, this anomaly occurs if the show file disk is left inserted into the drive on powerup.  When the disk is removed, the console boots normally.  This never was a problem before.
What do we do next?
