Hi Max -
Welcome to the forums. I've had a chat with the engineers who worked on Emphasis here at ETC and unfortunately, since the Vis side is crashing and the console side isn't it looks very likely that the problem exists on the Vis side. I suggest that you take the show file to your 3D Emphasis system and edit it there. It's possible that the problem presents itself on a 2D system but not on a 3D system. If, however, you see a similar crash on your 3D system, then that points to show file corruption. Since your files are older, it's possible that there is something in them that hasn't made the transistion to newer software well. If that's the case, you may have to rebuild the file from scratch (worst case). If you find that the show uneditable on both systems, you might try to import pieces of the show into a new show chunk by chunk. Sometimes this can clear out corrupted data, or at the very least reduce the amount of data you might need to rebuild.
I hope this helps -
Thanks much -
Sarah
Max,
You can have both versions installed on your machine - but they will need to be installed in their own separate path and directory. Emphasis Offline V2.7 needs to see the library of R17. I would recommend uninstalling and reinstalling R21 into its own directory, then install R17 into its own directory.
Hope that helps.
Kathy Williams
