How do you set them up to be board controllable? Looking in the manual, it said to look for profiles, but I havent found anything with Elation other than something I don't have.
thanks!
Laura
thanks!
Laura
Hi Laura,
You will want to download the Expression Off-Line editor. One of the parts of the download is a Personality Creator. You can use the software to create a profile for the Opti in which ever mode you are using. (I would recommend a mode with the master dimmer.) It is pretty easy to create a profile.
I have put one together that might work for you. Unzip & save it to a floppy and try it.
Good Luck!
John
Thank you so much for the reply... I tried loading that personality, and it said it was loading, then it didn't appear to do anything. Nothing came up. I downloaded the offline personality editor, and didn't quite understand what to do. I know how to set up one of these through a Leprecon board, haven't tried through this yet.
Thanks again!
Hi Laura,
I tried loading it in the offline without a problem before I attached it. Are you running 3..11?
Next, on the Fixture Personality Page it should just add the OptiPAR as a new fixture personality. There is no A-HA moment. It just loads the file.
Hope that helps!
John
