Channels automatically go to full power?
I'm using an ETC Express 48/96 and I'd like for some channels to immediately jump to 100%, even when the channel fader is at 1%. I know this is possible with other ETC products. Can I do it with mine?
I'm sorry if this is a re-post, but I don't even know what to search for to find similar posts, and I can't find it in the user manual. Any help would be greatly appreciated!
  • You can download a manual from this link: http://www.etcconnect.com/product.downloads.aspx?ID=20012
    To get full @ 1% you need to assign a profile to your dimmer. You'll need profile #6. The default profiles are listed below.
    Pre-defined profiles
    0 - Linear (not editable)
    1 - IES square
    2 - Slow bottom
    3 - Fast bottom
    4 - Slow top
    5 - Fast top
    6 - Full at 1%
    7 - Preheat at 5%
    8 - Preheat at 10%
    9 - Hot patch
    Here is the excerpt from the manual (pg41) about assigning profiles:
    "Assigning a profile to a dimmer
    You may assign one of the 32 alternative profiles to a dimmer. If you
    assign none, the console sets the dimmer to default profile 0, the
    uneditable linear profile. Following is the procedure for assigning a profile
    to a dimmer.
    Keystrokes:
    1. Press [Patch].  (Press [Dim] if the dimmer LED is not lit.)
    Prompt reads:
    Select dimmer numbers, then press
    [Enter] to assign to a channel, or
    press [At] to assign a proportion, or
    press Profile to assign a profile
    2. Enter the number of the
    dimmer to assign on the
    keypad.
    3. Press [S7], More
    Softkeys, [S6], Profile.
    Prompt reads:
    Select dimmer profile number
    4. Enter the number of the desired profile.
    5. Press [Enter]."
    [edited by: bosox242 at 12:50 PM (GMT -6) on Fri, May 27 2011]
  • Assigning a "Non-dim" type of profile to a dimmer will make it behave like this ALL THE TIME, in all cues, groups, and subs. If you want some lights to pop on whilst others are fading only in certain cues, use a multi-part cue.  Have the fading channels live in one part of the cue, and the instant channels on another, then set the desired fade times and wait times for each part.
