hello everybody, is it possible to change language on expression offline ? I would like to use French version
and with a light board, what is the way to load or choose French language ?
tanks a lot
tanks a lot
Hi Pilou,
It is possible to change language. I don't have permissions to attach files in this forum, so send me an e-mail or call me in the London office (+44 20 8896 1000) and I will e-mail the needed files to you.
In the folder where Expression Offline is stored (usually C:\etc\Eol\Eol31) there is a file called ENGLISH.LAN. This is the language file.
Now, when you start Expression Offline all text will be in French.
To change a console to French you will need a special version of the software. Contact me and I can send it to you.
Regards,
Tom
