Having trouble patching the elipscans ive tried a few different methods what is the best way of accomplishing this?
Roger;
Sorry to hear you are having problems. The Meteor Elipscan is not in the Emphasis Library. The Fixture uses 5 channels.
You could create a custom fixture with these attributes plus a remote dimmer for the fixture.
I hope this helps
Hi Roger -
Moving lights and scrollers need to be patched at a minimum using the DATA tab in the Emphasis Server.
There should be a description of this in the Visualization manual.
Thanks -
Sarah
