ETC - Community
Site
Search
User
Site
Search
User
Control Consoles
More
Legacy Consoles
Legacy - Wholehog 2
Modify a Group of fixtures
More
Cancel
State
Not Answered
Date
hawthorn - Former HES Forum Member
Date
Fri, Apr 14 2006 9:23 PM
Replies
Subscribers
4 subscribers
Views
Users
0 members are here
Hello,
I have a group of fixtures (6 desk chan) and in my second cue in my first cuelist I record this group with a intensity of 30%.
Well, now in this cue, I want to change the group... I don't want to have my 6 desk chan, but just the 3 first. So I modify My group... But in the cue all the 6 fixtures stay with the intensity.
And I don't have just a cue with this 6 fixtures, but 80. And I don't want to re-program all the 80 cue...
What's the solution ?
Thx
0
stephlight - Former HES Forum Member
over 16 years ago
modify the group is useless because the cues do not store the groups.
solution 1
load cue 1, select 4>6 , touch knock out, update, do the same with cue 2 if you have stored this fix in this cue too.
open cuelist option and take off maintain state.
Solution 2
4>6 @0 record merge 1>80 enter
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 16 years ago
Well the second solution is perfect for my application and work perfectly,
quick and easy
Tanks
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
rautasami
over 16 years ago
How about 4>6 @0 record remove 1>80 enter ? (no hard values)
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
jankirchhoff - Former HES Forum Member
over 16 years ago
Sami's suggestion is definitely the better one because it will kick out the desk channels 4 throught 6 completely out of the list: "4>6 @0 record remove 1>80 enter".
With "4>6 @0 record merge 1>80 enter" you will just have unnecessary values in your cuelist (every cue will have 4>6@0 in it!). That doesn't really matter if you only have desk channels, but will slow down the desk on bigger rigs, especially during programming. And it's just not the right way ;)
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 16 years ago
Of course that is better, I did not know this option "remove"!
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 16 years ago
Perfect for me the remove option.... that removes several hundreds of useless records...
Thanks to all
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 16 years ago
"record remove" and cloning are the most powerful tools on the hog2 - at least in my opinion ;)
If you have live shows (i.e. festival situations) and want cuelists for the colors on the wing, 2 for the spots (odd/even or something like that) and 2 for the washers, just make one list with all movinglights in them (which is done very easy when you have good palettes ;) ), label the cues, copy it 4 times and select all Washers but the first group. Hit PIG+ACTIVE to get all parameters in the programmer, select the first cuelist and type "record remove 1 thru enter". This will kick out all the lamps you had in the programmer. Do this 4 times for your for groups and you have perfect cuelists. Always keep your "master list" with all colors in case you want to change the grouping later. This saves a lot of time... do the same for moves, positions etc...
Jan
Jan
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
rautasami
over 16 years ago
:D Nice tip Jan!
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
