sub master
hi.
i am having a show that run in different places in the show i got
10x mac700
and 24 dimmer channel.
the problem is that in each place i have to use different level for the dim channel. it depend on the stage size and if it is an indoor or outdoor show
the whoelhog2 doesn't have a sub master and i can't use the master level because it effect on the mac700 output level.
so..... i have to go to each cue (and i have 160 cues) and adjust the dim level !!!
is does anyone have an idea to "fix" that problem ?!?
