Echelon
I have just bought a Echelon 1k and I am having a lot of problems trying to make a new fixture lib. I have used the fixture generator link on the flyingpig.com website but every time I try to load my new fixture I simply can not find it on the fixture list. The light is made buy star and it is a copy of a mac 250 kr. I have tried to merge it with show and just load it a new lib but I can never find it. I have attached the fixture paramerters if anyone can help.
fixture = star
manufacturer = 76
product = 1
name = star250
yoke = yes
//Created using Denis Hessberger's Wholehog2 Library Generator application!
output = dmx
parameter = Strobe
default = 220
highlight = 220
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 15,closed
range = 16, 207,strobe
range = 208, 248,open
range = 249, 252,reset
range = 253, 255,open
parameter = Intensity
default = 255
highlight = 255
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 255,%
default = 0
highlight = 0
crossfade = 0
movement = normal
type = ltp16bit
range = 0, 65536,%
parameter = Color
default = 195
highlight = 195
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 153,scroll
range = 154, 158,darklav
range = 159, 163,yellow
range = 164, 168,magenta
range = 169, 173,amber
range = 174, 178,green
range = 179, 183,lightlav
range = 184, 188,red
range = 189, 199,white
range = 200, 227,cwscroll
range = 228, 255,ccwscrol
parameter = Color
default = 0
highlight = 0
crossfade = 0
movement = normal
type = ltp16bit
range = 0, 65536,%
parameter = Gobo
default = 0
highlight = 0
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 4,open
range = 5, 9,1
range = 10, 14,2
range = 15, 19,3
range = 20, 24,4
range = 25, 29,5
range = 30, 34,6
range = 35, 42,7
range = 43, 50,1>
range = 51, 58,2>
range = 59, 66,3>
range = 67, 74,4>
range = 75, 82,5>
range = 83, 90,6>
range = 91, 104,7>
range = 105, 119,7shake
range = 120, 134,6shake
range = 135, 149,5shake
range = 150, 164,4shake
range = 165, 179,3shake
range = 180, 194,2shake
range = 195, 209,1shake
range = 210, 232,cwscroll
range = 233, 255,ccwscrol
parameter = Gobo <>
default = 0
highlight = 0
crossfade = 0
movement = normal
type = ltp16bit
range = 0, 65536,%
parameter = Focus
default = 128
highlight = 128
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 255,%
parameter = Fx/prism
default = 0
highlight = 0
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 31,out
range = 32, 255,in
parameter = Fx/prism<>
default = 0
highlight = 0
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 0,no rot
range = 1, 85,cwrot
range = 86, 170,ccwrot
range = 171, 178,no rot
range = 179, 255,random
parameter = Pan
default = 128
highlight = 128
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 255,%
parameter = Tilt
default = 128
highlight = 128
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 255,%
parameter = Panfine
default = 0
highlight = 0
crossfade = 0
movement = normal
type = ltp16bit
range = 0, 65536,%
parameter = Tiltfine
default = 0
highlight = 0
crossfade = 0
movement = normal
type = ltp16bit
range = 0, 65536,%
parameter = P/t speed
default = 0
highlight = 0
crossfade = 0
movement = normal
type = ltp8bit
range = 0, 255,%
  • what I remember from my old echelon is:
    first leave a 'return' between all the different parameters ( like a 'return' between the last parameter 'range = 0, 65536,%' from panfine and the start for tilt fine.
    then put a copy from your desk-lib-file on a computer, and also this new-to-import-file.
    In a text editor copy all the parameters for your Star250 and paste them in your desk-lib-file.
    Then on top of the desk-lib-file you have to increase the count of fixtures with 1
    put this new desk-lib-file in your jands and the Star250 should be visible. If you get errors during start-up / show-load: I don't know this fixture, so if the dmx-datasheet is o.k., you'll have to find out...
    Peer
  • [quote=osmosis;35603]I have just bought a Echelon 1k and I am having a lot of problems trying to make a new fixture lib. I have used the fixture generator link on the flyingpig.com website but every time I try to load my new fixture I simply can not find it on the fixture list. The light is made buy star and it is a copy of a mac 250 kr. I have tried to merge it with show and just load it a new lib but I can never find it. I have attached the fixture paramerters if anyone can help.
    The way I do this on the 1000 is to save my show, copy _lib.lib to my computer, tag the new data to the bottom, and make sure that the count at the top gets incremented by one. Write it back to your show disk, and it should be available for use, and no merging required. There are pretty good details in the Hog-2 manual, which (I think) is still available online from HES.
    I don't recall spaces ever making a difference, but can't swear that they don't . . . but miss incrementing the count field at the top of _lib.lib, and the desk will be deaf as a telephone pole to your new entry . . .
    - Tim
