Correct you are, however it's missing from the drop down list and you cannot simply type T7 as you would with Hog 2 so that if the list moves master it would still work. I presume a better syntax would be GL5/7 but even this is still long winded.
I don't exactly understand what you mean. Obviously if you prefer the macro to be connected to the list that is even better. The sintax would be GLx/ytz. As you select your macros cell you want to enter the macro in, the drop down menu pops out from which you can choose GL and straight after you have to type in cuelist number,"/", number of the cue you want to go to and eventually "t" and fade in time if necessary. You think it takes too long? You think we need a shortcut here? that 's what you're asking for? In the drop down menu we should have the GL_/_t_ or GM_/_t_ option available and by the time you choose one of the mentioned options what you have to do is simply typing 3 numbers in? cheers Marco
All I'm requesting is a "goto" command which will go to a specific cue within the same cuelist without naming the master or list implicitly. Hence when the list is moved or copied the command remains in tact.
