Inserting a follow
Besides typing a time, inserting a follow is probably the most used input for the wait column.
It currently involves several actions to insert a follow (as far as I know). You have to select the cell, press [set] and the select follow on the touch screen or use the mouse.
I was wondering if there could be a short cut for inserting a follow.
I was thinking about using the PIG button for that. So when you hold down pig and click on the cell in the wait column a follow is inserted.
Does anybody else have some input on that subject?
Regards,
Gertjan Houben
Moving Lights Support
gertjan@showside.com
